Spikmun
I recently bought some fuel for my Nitro RC car that has been sitting collocting dust for a while, The car is literally brand new it has never been driven since it was bought and has only been started a few times since (with problems). So i do everything as the manual says, I fill the tank with 20% Nitro RC fuel, I then manually open the throttle and pull the pull start untill the fuel has reached the carburettor, i then pull it 3 more times (to prime it). I then put the glow igniter onto the car and pull the pull start and the car goes absolutely crazy, One time the fuel in the fuel tank started bubbling because it the engine was going so fast, So i quickly grab the remote control and pull back on the throttle to stop the car from throttling so much (The car is held off the floor on a brick), I then pull the glow igniter out and the engine cuts off instantly.
I realy have no clue with Nitro RC cars and help would be much appreciated! I have also set the high speed needle to what it says in the manual (i turned it clockwise untill it wouldnt turn anymore, i then turned it counter clockwise 2.5 turns). I have no idea what I'm ment to do with the idle needle, I guess i need to sort that one out when the engine is running to get it just right?
Thanks!
Thanks!
