MAD-MAXX said::flamer: I'm glad your savage .25 is working now it is a great truck :jet:
LMAO! I've done the same thing but it was something different, I tried to fix it three times before it finnally worked. Good luck geardigger, stick with it.Savage.30 said:I did it twice. On the same truck. On the same night. trying to fix the same problem.
CorradoPsi said:prather medium fuel line, or dubro blue NOT DUBRO YELLOW(they had a bad batch and its fouling glow plugs) when you run your fuel line and pressure line, make sure to keep it away from moving parts and hot parts.
it sounds to me, as if your LSN is too lean, and your HSN is too rich to make up for it. back the HSN off to the factory settings and then turn it in 1/2 a turn. turn your LSN until its flush with the outer edge of the horn on the slide. this should get you started. take off your filter and look down inside the carb. when you hit the brakes and in neutral, there should be a 1mm open gap in the carb, if it closes when you hit the brakes adjust the idle speed needle until its right. while you have the carb off, make sure that when you hit full throttle the servo is only opening the carb the whole way, and no extra, this can cause the carb to stick WOT, if its pulling more, adjust your endpoints on the radio. put the filter back on. once the truck is running and hopefully up to temp. pinch the fuel line just before the carb. it should take 4-5 seconds for the engine to rev up slightly and stall. if it takes longer lean it out until you get in that 4-5 second range. if it just dies, richen it up until your in that range. now you can slowly pull the throttle until your at WOT, if you just grab the trigger the engine will stall. you want to adjust the HSN until you have good power, smoke, and the engine sounds like its clearing out. turn it in 1/8 turn at a time to achieve this.
geardigger said:Thanks, will try this when I wake up tomorrow afternoon.
beason said:lol wtf man i wouldnt be able to sleep let alone sleep till tomorow afternoon.. WAKE UP BOY!!!! and get that damn truck running.. so you can break it..
beason said:ahh 3rd shift.. let us know what happens bro...
beason said:damnit boy..
is this your first r/c??
which gears?? back plate or starter??
