What keywords did you use to search for them on ebay? Also where did you get the voltage screen and the case? Also, where did you find the info on how to wire them up in series? I may end up trying to build something similar to that myself later this year.
The powers supplies are DPS-600PB models made by Hewlet Packard. There are several power supplies you can use, just need to pick what works best for you in your application. In my case I picked the supplies based on the charger, they will nearly allow my charger to max out on a 40a charge
The voltage screen I picked up from ebay, it was cheap..Make sure when you search for them that you click the US seller only tab or you will get a bunch of results from over seas. You can also get a Voltage/Amp gauge but it's a little than just 2 wires to hook up. I picked one up but opted out of using it due to space limitations in the case. That shunt is pretty big :\
As for the information I found....Well I actually found a guy on ebay that sells these already done up (search for Powerlab 6) and that is what initially lead me to more research. I ended up finding a website by a guy named tjinguy that has alot of useful information, along with the needed pins to turn the units on. Other than that I just pulled it apart and wired it up without any sort of specific guide. Now after I wired them up the first go around I stumbled upon a very very lengthy thread on
RCGROUPS specifically related to these two power supplies. That my friend has all the information anyone could ever need. You have to weed through the pages to get all the good information but its there, trust me
The idea for putting it in a case came from ProgressiveRC, gotta give them some credit, which is where I bought the charger from. Also some of the connections and wire I used came from them aswell...They sell top notch products!
The case I used is a Pelican iM2100
That is a totally professional piece of work. Beautiful job.
Thank you sir! It's so pretty I almost want to stick it on a shelf and just admire it
Awesome work dude, That's the only way to make it portable using two server supplies. I think people just think we carry two about with a charger.
Yeah, a couple of my buddies kind of thought I was weird when I showed up carrying two server supplies velcrowed together and my PL6. They didn't say anything else after I charger a 4s 6000 mah battery in 12 minutes
: I can't wait to see their faces when I walk up carrying this....lmao
