I
i_am_ed
Guest
Okay, a follow up to my introduction post:
My first 3 or 4 tanks were exactly per the instructions that came with the truck (Team Associated Mini MGT 3.0). Briefly this is: First two tanks with the HSN screwed out 2¾ turns (stock setting normally is 2½ turns). Third tank at 2½ turns and the fourth tank 2¼ turns.
This seemed to be fine, although I was suspicious that the engine was too hot at times - a water drop on the head was sizzling off within a second. However, the engine wasn't actually running long enough at any one time to stay really hot. The issue was, the engine just wouldn't run over half throttle. It would accelerate with plenty of blue smoke but anything above half throttle - bam, stalled.
Here's a video of it.
Sorry about the poor quality, was using my phone.
Some helpful people at aeforums.co.uk suggested it sound like a lean stall, simply as if it was running out of fuel. Running the HSN screwed out by 3¼-3½ turns is much better. It's not tuned perfectly by any means, but now I can get to WOT without a stall
I think the LSN needs to be leaned a touch, but that's by-the-by.
But, at times I think the engine has got really hot... hot enough to make the WD40 residue smoke. Also, when the engine was new there was decent pinch, but now if I turn the engine with the plug out there's just a hint of a pop as the piston goes through TDC. Is that a sign of undue wear? There seems to be decent compression with the plug screwed in, however. I also took the head off to have a look - there's a small amount of pitting on it and it's a mid range golden colour whilst the piston is a little bit darker.
What do you think? Has the engine had too much of a hard time during the break-in? Is the fact that the HSN needs to be a full turn richer than the stock settings a sign of a problem? I've taken the HSN assembly apart to clean it but I couldn't find any debris lurking inside.
I'd be interested in your opinions, or am I getting worked up over nothing - I should just tune it up wherever the engine wants the needles to be and ignore the stock settings?
Ta
Ta
