Mbx4 rear shock case part number
Is this it? It shows C0524 and C0525
Measure the length of the shocks and search for ones in that range is all I can tell ya. I have no experience with that kit. Maybe @cbaker65 can help ya. Not sure, but he has had lots of different kits like that.
My buggy has a big bore in the front and one in the rear it’s that how they come
I was about to buy it too but I don’t want to pay 130 but this next gen look like they could work
Found these
It’s it normal to have a big bore & skinny in the front and the rear also has a big bore & a skinny bore?
Thanks for the props ,but I don't stomach those prices quite well either an will totally refuse to buy parts that
are that high ,I would rather find a used part or a chop shop even if it is off of another brand!..🤔:thumbs-up:
Might can check out this store!
May can try the shock set up from the next gen. as Mugen put out.
https://www.ebay.com/itm/392383104399?hash=item5b5bdb058f:g:ovUAAOSwuW9dVI5Q
So my car came with a big bore on one side and skinny on the other in the rear and is also in the front that’s not good right baker
That tells me that some else may have broken a shock before ,an used what they had!
I noticed on some didn't have thread , my guess ,they used some kind of boot or just a o-ring seal
inside the shock?
I would think that you can use any shock as long as they are the same length as the originals ,so you
might want to consider on buying a new set at a descent price ,better in the long run!
There is a ton of old Gen mugen parts on E-Bay right now ,so my guess ,some one has a mother load!..🤣😂
It used boots but I’m still doing lots of research this cars are 25+ years old. I don’t really need lots of parts just the shocks look weird to me not sure they are stock. Here’s pictures I still need to clean it up then I can make alignment adjustments
The front side also has a little more slack on the springs on the right side
Yea ,Mugen is a top well known contender an is an expensive racing platform ,what parts I seen ,old & new ,are expensive ,an
In fact ,someone on ebay has your mbx4 brand new never built kit for a $ 1000 bucks!..🤣😂
I think that I would just find a new set of shocks ,or find a rebuild kit for yours ,o rings do rot an go bad ,I'm also seeing
Conflicting shock #'s on that manual ,but I am also seeing a lot of those mbx4 parts on ebay ,but some are pricey!
Mugen tends to use the same MBX letters on everything ,it can be confusing on what model they are referring too ,check
Out this shock housing kit ,they just say MBX ,but there is a part # ,but does not match yours!..🤣😂
https://www.ebay.com/itm/183619462265?epid=20026909287&hash=item2ac092a479:g:NgkAAOSwgotcLo8y
I seen that. That kit is for a newer model ( mbx5) I guess I’ll get that set and maybe the front set just to have a fresh set. I have a couple oz of 70 weigh fluid I might use
