I don't post on here much, but I thought I would share what I did to make my own headlights. The car I did this on is a HPI rs4 3 type SS. Basically what you need is some wire, 16 gauge works well, smaller wire would be fine. You also need 2 AA batteries. 2 LEDs in the color of you choice.(you can get LEDs cheap off of ebay) Also a battery holder would work. Basically I had a battery holder that had wire already on it with terminals touching both sides of the battery.
This is the battery holder thing:
I mounted the holder to the spot I thought would be best. Then I ran wires up to where the LEDs would be. I made holes for the LEDs and wired everything. I ran the positive and negative from the battery thing to one spot then had them split off to each headlight. Once I figured out the layout I used a soldering iron to connect it all. I then taped all the wiring to the body so it wouldn't move much.
Once it was all hooked up, I put the body on and it looks like this.
Just thought I would share. This was just a quick thing I did and I think it turned out pretty well. If you really wanted to you could run the LEDs off the power on the batteries on the car but then you would need to connect it and disconnect when removing the body. I have something even better planned for a body I'm going to paint this week. Any comments/ suggestions?
