hi,
i have installed a new thunder tiger .28 engine on it. When i started with the break in process ,i faced a problem.
The engine starts only after i hit more then half throttle.(CARB OPENS TO 1/2.)
The engine dies immediatey if the throttle is less then 1/2 throttle.
Now if i run the engine more then half the throttle for 2 to 3 mins the engine temps rises to 200F, which i guess is not the ideal temperature.(HSN IS 3.5 TURNS OPEN)
what needle adjustment should i do?
The ideal screw is set in such a way that when full breaks are applied the carb is open to 1.5mm.
can an air leak in the carb be a problem to this?
