Aluminum C-Hubs (?) - I just recently broke a c-hub for the first time a few weeks ago. I ordered GPM aluminum replacement (mainly cuz they were the only red ones I could find.) GPM stuff is decent but not quite as strong as Dynamite. I try to get dynamite aluminum parts for it when I can.
Aluminum Shock body (?) - can't really say much here. I bought aluminum shocks for mine and never even tried using the plastic ones. Personally if you got the money I would go aluminum here but The plastic ones will probably be fine also. I've never read anything about folks having issues with them.
Dynamite Fuel Filter (Big Daddy) - +1
GPM Engine Brace - I would try to find Dynamite but anything is better than the stock brace.
Losi Dual rate springs (yellow?) My springs arent dual rate but they are yellow. I like those for big jumps.
Losi Hard Ano Front Skid Plate - I wouldnt bother. Other than looks. I've never worn out a normal skid plate.
New Era Roll Bar - I never have but alot of guys sing the praises of this hop-up.
RPM A-arms - For me its a must for the fronts. I never put them in the back because i dont believe I've ever broken a rear arm.....its always the fronts.
Shock covers (Losi?) - Bling...nice looking but not necessary.
Shock Oil (?) - I use 60wt along with yellow springs. brand to me doesn't seem to matter much. I usually use the cheap stuff that TheToyz.com carries. cheapest shock oil I've found and every bit as good as Losi brand IMO. I think its Racers Edge brand but Id have to look to be sure.
BAC Link (?) - never needed them but I know Schroemode used it.
Ball bearings (?) - I just use cheap rubber sealed chinese bearings if/when I need replacements.
Battery Pack (?) I just bought a couple extra of the stock 5cell NiMH packs it comes with and use those.
Lunsford Titanium Turnbuckles (?) - I've only ever broken one turnbuckle so i havent hopped those up yet but if I was going to this is what I would use.
M2C Motor Mount (?) - I've never had a problem with the stock mount.
TiNi Shock Shaft (?) I have the TiNi in the fronts on both my XXL and my LST2....Never had a reason to replace teh rears.
Set screws (?) - If you actually mean set screws I'm not sure what you are referring to. If you meant a screw set in order to have spare screws I would look on ebay. there are a few on there.
Sway Bar (?) - I havent gotten around to trying out the sway bars....I've been wanting to for quite awhile though, at least on my LST2-E
EDS Hex Drivers 1/16 & 1/32 (?) - I own an entire set of Team EDS hex drivers and their exhaust spring tool. These things are boss. The tips are made from spring steel and the tips edges are ground so they have alot more bite and alot more strength than most other sets who use cast metals for their tips. The EDS tips are made from the same material, in the same fashion, and some folks claim they have their tips made by the same company that makes Hudy's tips. I believe this to be true since the tips look virtually identical to Hudy's but at a much cheaper cost. That is unless you have them engrave your name on them like I did which costs an extra $2 per tool. The 4 piece set (either standard or metric) is $40 plus shipping. Both sets together without engraving are 80 bucks, Hudy's are $118 minimum if you can find their big 8 piece set in stock. I ordered the 8 pieces plus the additional spring tool with all 9 pieces engraved plus shipping for $117 bucks. Love Team EDS I hope they never loose their quality.
Locktite (?) - always need blue
Allen Drivers (?) - See Team EDS above
Additionally I'll add that I personally like adding the LST2 wing to the kit myself Hope this helps.
Those Springs say they are for the LST.....Will they also fit the LST2/XXL?
