jwx
Has anybody ever used a block of the foam that they use in fuel cells to help combat this? I'm thinking about getting a block and cutting it to fit.
You want to put a piece of foam in the fuel tank?
Not really RCA. My hypothesis is more inline with rak. As the fuel level in the tank decreases the air level increases. As this happens there is more air to absorb the pulses and pressure from the exhaust, thus as the tank empties more pressure is absorbed (air comresses, fuel does not) and less pressure is transferred to the fuel lines and the carb. It's not really that the air in the tank just soaks up the pressure, it has to go somewhere, but I think a portion of that pressure may be lost back to the exhaust line during the voids between the pulses. When the tank is full there is minimal air to absorb and redirect so the pressure is more constant to the carb.
I've had fuel slosh cause cutting out with my tmaxx before. Fuel was low, spinning doughtnuts to the right, causing the fuel go to the left side of the tank. Maybe longer fuel line will help, but I can't help but think that there will be an air bubble that will interrupt the flow of fuel. Probably wouldn't matter much, but I could see how it could.
