This is the stock engine that comes with the PRP Swift RTR models.
It's a 3 port engine (4 if you count the exhaust port). The carb venturi is quite narrow and the port timing is conservative. The engine's main strengths are therefore low- and mid-range torque. A top-end screamer it ain't. Some people reckon that it runs a bit on the hot side. I think this is a consequence of the narrow carb venturi (can't get enough fuel through at high engine speeds) and the heat sink that is noticeably smaller than other .21 engines. Virtually any 4-screw heatsink will fit (I use a Savage 21 heatsink).
Having said that, daveg in the Swift forum reckons that it can be livened up a bit with some porting work but will still pull OK on a 15T clutch bell in a buggy. I have a couple of these engines for my Swifts and will be doing some experimental porting work on one that is starting to wear out a little now.
AFAIK, the XTM 24.7, Dynamite and Mach engines are all made by SH in Taiwan.
