blackgold
Hey guys, bought this thing spur of the moment.. it starts up great.. runs good. The front wheels are not spinning. I played with it last night, to sort it out, determined that the main belt going to the front was not spinning. Tried to remove the circlip on the spur gear? to slide the gear that turns the front off. It didn't want to come off. I started trying to disassemble the car to get the whole gear set out. Gave up on that, put it back together to test something else out, and had front wheels. I took it out today to test it out, front went out after a bit. So I'm thinking I need to replace that spur gear assembly? What is the easiest way to remove the assembly? Also, it was SUPER sensitive to steering input. if you touched the steering while moving at a decent speed, it would spin out. Also, it seems to have a serious lack of traction, I know only being 2wd doesn't help, but what is a good tire that is durable and functional? the tires on it were worn down
Thanks,
Brian
Thanks,
Brian
