thx for the advise kuma, but they were tight, i've decided to complain to Kyosho about the cars enigine and their setup instructions, if i can find somewhere to send it, here what I'm sending them what you think they'll say
After much consideration of the available 1/8th buggies on the market and my budget I recently decided to buy (11/10/2003) an Inferno MP7.5 Sports.
After reading the instructions, making sure the engine settings were correct (Needle Value, Air/Fuel Mixture, Throttle Value Adjustment Screw) and having to wait a very inpatient 17 hours for my glow starter to charge I began the braking in process.
My First problem arises here, I get engine running but have problems getting the engine to idle correctly, it would settle but then the RPM of the engine would start to rapidly increase, for no apparent reason? I would then stop the engine because of fear of over revving the engine at this stage of its life. After spending sometime and approximately 2/3rds ish of a tank of fuel I decide to phone the shop I bought the car from for some advise and if they would correct me if things were wrong.
Returning to the shop the following day, the shop assistant gets engine running and starts to encounter the same problems I was having, he then realises there is a problem with the Air/Fuel Mixture screw setting and it is set to run without the air filter? So he readjusts the Air/Fuel Mixture screw and bingo the engine is idling correctly and the problem is solved. So I return home and continue with the breaking in process, running 2 tanks of fuel with car sitting off ground idling. Then I begin to gently run the car on a flat tarmac surface, applying throttle gently, never full throttle, I do this for a further 3 tanks of fuel. For the next couple of tanks of fuel I start to run the car slightly harder with each tank of fuel. I would also let the engine cool before the next tank of fuel at all times.
Anyways approximately after 2 litres of fuel and 2 weeks later I notice something different about the car just doesn’t feel the same, there’s a loss in the cars performance, and its getting worse. I’m puzzled it can’t be the engine already, after much reading about nitro engine problems etc. I begin to think there’s a problem with the engines compression and to my surprise there is, the piston and liner are knackered. Now at first I was upset at the thought of just spending £400 and having a broken car already, but then just had to accept it. But after further reading about nitro engines, breaking in etc I feel that I have done everything correctly and think that the engine has incurred damage in the initial getting the car running. I feel the problems I encountered at the beginning are due to the set-up instructions given with the car. Why would I want to break in the engine without the air filter? , So why give me these settings?
I ended up going with a car Kyosho car on returning to the scene from a 12 year or so break. I had Kyosho cars then to (Laser ZX, Optima Custom Special) and thought they were great cars with a ready supply of spares. So I begin to accept I was having replace the piston and liner of my new car at the cost of £40ish, so the hunt begins, guess what, I then find out that there is a problem getting hold of the GX21 pistons and liners and its probably going to take a least 2-4wks maybe longer, there’s a shortage. Now I’m very angry and upset as I’ve spent all that money and now have a buggy shaped DOORSTOP and the worst thing is only thing I can do about it is buy a new engine. I was planning to do this but not for another couple of months. What am I meant to do Kyosho, HELP ME OUT PLEASE, I WAS GOOD ENOUGH TO SPEND MY HARD EARNED CASH ON ONE OF YOUR CARS CAN I PLEASE AT LEAST HAVE THE BACK UP. PEOPLE THINK I’M STUPID SPENDING ALL THE MONEY ON A RC CAR I DIDN’T!
Yours a very disappointed customer
Doby
Should have waited for that Hyper
