alright well I'm not sure if my revo is the 2.5 or the 3.3.. but it has the OptiDrive system.
it sat for 2 years or more up in my attic. got it down, got it running, and whenever i try and go forward it barely moves, even with full throttle. i replaced the spur gear since i saw the teeth were badly chewed up. that wasn't the problem. so i took the transmission apart and everything seemed just fine in there.
i believe its the optidrive system.. in the manual its telling me that if the throttle trim is messed with then the system will need to be re-programmed.. could that be the reason that it wont even shift into any gear by its self?
when i move the shifter button on the controller, it doesn't shift like it should.. and i have no clue what is up.
