Hpi Rs4
Register Log in
cul8ter70
I was wondering what would be a good engine for it don't know if it matters but its not belt driven any help would be great
Thanks
NitroHawk
RCNT Member
Buenos Aires, Argentina
Bashing, Racing
It all depends on your budget and what you are using it for.
Cheap engines like this won't last long and can be hit or miss when it comes to reliability and power.
You could also get an HPI engine like the ones that came with the rs4 such as this one
Or you can have the more expensive option, an OS engine with great power and durability, very easy to tune.
As I said, it all depends on what you want it for.
Phins Fan
Hardcore RCNT User
Keeping warm in a fat roll somewhere.
Bashing
IMO the HPI 3.0 is a junk motor and best served in a landfill, Nitrohawk did point you in the right direction with OS as they make great and easy to tune engines that are very reliable. Anywhere from a .12 to .15 would serve that car fine. Anything bigger like a .18 or more will probably start breaking other parts on the car because of the excess power they produce
cul8ter70
Thanks a lot nitrohawk I have one of those os engines so I'll put that in it now is there anything I'd have to change cause of the more power?
NitroHawk
RCNT Member
Bashing, Racing
Which OS engine do you have? Is you RS4 a belt drive model or shaft drive?
You should be ok with a .12-.15 on stock configuration, the .18 can stress the differentials too much, mostly when used on high grip tracks. In other cases the wheels will just break traction and take some load off the diffs so you shouldn't have any problems.
cul8ter70
I have the 18cv-r and it does have shaft drive so I would be better off with the .12 or the .15 what brand would be good
