Hpi baja head gasket help!!
sAvageXl
Australia
Hi guys, really need some help here.
So I've just taken apart my stock cy 26cc fuelie engine to replace the very worn leaky head gasket. I ordered a zenoah 2 bolt gasket to replace it and the website said it would fit the cy engine. So i test fitted it and it looks like there are some gaps near the center of the engine and it doesn't line up perfectly, should I go ahead and install it or not? Ill attach a photo. Any help would be great.
It looks good to me, granted it is a little thin on the two sides but I have used similar shaped gaskets and had them hold.
thanks for clarifiying that. Was super freaked out fro a sec. My dad thought the same thing as you, as long as it seals the outside properly should be good.
