"Fastest" Mini-T
Being the head Mod at
YourMicro.com I get to read every aspect of Members wanting, claiming and achieving speed in their Micros.
The Mini-T's biggest downfall in it's standard form are the lack of bearings and substandard electronics including the FET-less steering servo (servo FETs are on the RX/ESC Combo) A battery pack can make all the difference as can bearings and a decent motor.
Brushless seems to be everyone's "quick cure" for speed, but the problem is that some of the brushless systems out there are just "too fast"
The Mamba 8000 for example is insanely fast, I have one and I wont use it in any of my Micros as they just cannot handle the insane speeds the 8000 motor achieves
More importantly, the faster (6800-8000) motors put intense strain on the drivetrain causing spurs/pinions/diffs/dogbones/CVDs to wear prematurely.
Another factor most people overlook is the result of a high speed incident with a Micro. I've seen many a Micro converted to shards of plastic/CF when losing it at high speed with both Brushed and Brushless motor setups
The sweet spot is what the owner wants, if he wants an 8000 then dig deep because you will turn your Micro into a money pit by having to reinforce the chassis and drivetrain
A Mamba25 5400 option would be more sensible as it has more torque than the 8000, is plenty fast enough and wont grind your drivetrain down.
For a Brushed solution I suggest the new
United RC Krystal motor
This thing has balls and if it's combined with a decent battery pack you'll have all the speed and fun you could ever need.
Let us know what direction you took and how it turns out
