Honcho Mip driveshafts
theant
Calgary, Canada
Anyone know what is the difference between Mip driveshaft part number 8101 and 10145. One is made for the scorpion and one is made for the scx10 models. Both are more or less the same length but the 8101 are cheaper.
Have any of you used the scorpion shafts (8101) on your honcho?
Sent from my iPhone using Tapatalk
The AX-10 and SCX-10 share a lot of parts. The short wheel base version should use the same drive shafts as the Scorpion, if I remember correctly.
Sent from my padded cell...
They are minimally different in size and are compatible with both. As Hamz stated a majority of the AX is the SCX. With the exception of the shocks and TVP's I believe everything else is compatible so you can save some good coin if you shop right
