Macguyver
here it is
i made this with an old rotary tool....the chuck on this one is not the original , this one is a bit bigger than stock one ( due to a bad tinkering day and it ended up at the other end of the yard with a bent shaft coupling ) lol....this chuck is from a cordless screwdriver ..i just press fitted it to the shaft ...but I'm pretty sure the original chuck would work to
i took all the electricals out of the tool , and i was left with a balanced shaft with good smooth bearings
for the hub , i suggest using a spare wheel hub ..or maybe an old one for the wheels you have ...i didnt have any so i found an old screwdriver bit holder that would fit perfectly once i trimmed the edges off ..and it would screw in nice and tight on my shaft ......but an original hub is the way to go if you ask me
once i made sure everything turned strait using a carpenter's square as an edge , i glued the shaft with ''J-B weld'' epoxy
it turns really smooth , i use silicone spray lube on the bearings ....
i got the idea when i saw one on youtube (a real one )..and when i saw the price online ,40 to 50 $ , i said to myself ..'' poop , i can prob make one ''.. .. i had all the parts laying around
so there it is
cheers
so there it is
cheers
