DougJorgie
I have a Traxxas TMaxx 3.3 and I am having a hard time getting my temps down and also getting a nice smoke trail no matter what I do. I found that my fuel cap was not sealing properly...fixed that and it helped a little. I had my truck out yesterday and couldn't get the temps down to 220-240. I kept making the HSN richer until it was bogging down and wouldnt get the rpms high enough to shift to second. I leaned it out a little from there and it seemed OK other than the smoke trail. The smoke trail is good at lower rpms but it disappears as the rpms go up until it is barely there at high rpms. There was nothing I could do to get more smoke so I moved to tuning the LSN. I have that to 3 seconds on the pinch test. I didnt have to mess with the idle because it was nice and low and it would idle steady without any stalling. So, in theory it sounds like I have this tuned good(other than the smoke trail), right? Here's the problem...when I am running it, it does not come down to a nice idle when I let off the throttle. I have to feather/play with the throttle to get it to come down. At this point when I check the temp it is usually around 270-290. Could the temp be high because the rpms dont come down to an idle when I let off the throttle. So I am thinkin when I am running the engine never slows down to an idle causing the temp to constantly go up. I was also wondering if it could be the Tower Hobbies 20% Nitro fuel I am using. What do you guys think? Keep in mind that when I broke in the engine I could not get it to run consistently, the fuel cap was not sealing and I was and still am using the Tower Hobbies 20% fuel.
