Blu_boost
So I got my tmaxx built again and pretty noob at tuning. I understand the concept but haven't had enough time (yet) to practice it. I have a few things i can't figure out and need your input, Please.
Its dying on high speed without shifting. Was lurching forward so i richened the LSN (is little increment better?). Idle was normal and pinch test was sounding about rite(popped wheelies). The engine is at the point of RPM's, that shifting normally happens but doesn't.
Fyi this the first time i really ran the tmaxx after buying.. so not to familiar. Tore it down and went through the whole truck. Umm Wondering if something wrong with transmission? Also aware of front bearing air leak so could this be causing all my problems? Should get the crankcase & bearings tommorow and have a fun time with bearing removal. Also are the hex on the backplate metric... none of my SAE hex kit has the size (2.5 i believe).
ThankyOu!
ThankyOu!
