Have I damaged my engine
GTee
I have tried to break in my Hyper 7 TQ black's enginge today ( Hyper 21 3p) and I can't get the temp up to 200* no matter how much I lean it out the closest I have got is 155* with tin foil round the head. I have been back out tonight and put 2 more tanks through it now, 5 in total and can only get about 130* now, I have turned the hsn about 3/4 turn in total to try and get it near 200* but no luck.
All that happens is it runs a couple of mins then bogs down and cuts out, the outside temp is about 35* will this make a difference? I am using Byrons gen II 25% nitro witch the shop that I bought the Hyper from said to use. Also my glow starter battery isnt up to much as it wont last long the lhs said to charge it for 6.5 hours, its a 3000mah and the chargers out put is 450mah.
Thanks in advance.
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
You're running very rich in very cold weather. Not a good way to break in an engine. Breaking in is all about heat cycling to get a good fit between the cylinder and piston. Running too cold and too rich will not do that. Leaning it out too much in an attempt to reach higher temps will starve it for oil and ruin it for sure.
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
Wrap the head with a paper towel/ziptie or the top of a baby sock. This will help keep the heat in and let the temps climb without excessive over-leaning. Just make sure to not run it where the towel or sock will get wet as this will make it worse than what your currently dealing with.
Depending on how much fuel you've ran, you may be ok. Granted, not the best case scenario for a new engine, but it should run for a while.
I make it a point to not break-in an engine when it's below 50F out. But, I have old engines I can run in the winter, so I'm not stuck with a single engine world. ;)
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
Try wrapping a cuff or 2 from an infant's sock around the head. Run with the body on. Go back to factory settings and see what temp you get, then start from there.
I won't even run a well broken in engine when the outside temp is below 40. With a new engine it's a real strain and will shorten it's life time.
GTee
I have set the hsn back to factory settings and I will wrap a sock around the head and try it again tomorrow. Since it has had 5 tanks through it how should I run it? and if I can't get it to 200* what should do.
olds97_lss
RCNT VIP
Dekalb, IL
Bashing
Start saving for a new engine... then go beat the snot out of this one and if it lasts the winter/colder months, then keep it as your winter engine.
Probably your best choice anyway. Then you won't have to worry so much next winter.
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
B Water damaged engine, can't start Nitro RC 12
NurturantQuasar Li-Po batteries damaged? Electric RC 2
N Attempting to restore damaged buggy Nitro RC 6
buggybuster esc or reciever damaged Electric RC 5
A sea water damaged nitro truck Nitro RC 8
M Damaged Header Seal.. Big Deal? Nitro RC 4
W Damaged kyosho flywheel spacer and shim?? Nitro RC 0
M After a day and i already damaged it. Buggy and Truggy 13
jlobbia What should I do when my engine loses compression? Nitro RC 4
jlobbia What is the biggest nitro engine ever built on a monster truck? Nitro RC 1
G Kyosho inferno neo 3.0 nitro engine help Engines 4
Harryp123 Hobao Hyper ST engine qualms Nitro RC 0
Z Need help identifying this nitro engine! Engines 10
Connor_TK.Extra Engine bogs down and cuts out at 15ish mph Nitro RC 4
jlobbia Tmaxx engine is fine but barely moves Nitro RC 27
S T Maxx 2.5 engine issues Nitro RC 19
jlobbia Engine block to cooling head threads stripped! Nitro RC 3
H HPI bullet st 3.0 engine may have low comp Engines 1
A Replacement Parts: Bad On/Off Switch and Engine Screws Nitro RC 4
EngineDIY A new Toyan AC Engine. Needs Advice for Better Use. Engines 0
H Savage Xl K. 5.9 engine alternative Engines 8
Matty1933 Hpi rush evo maybe engine swap? Nitro RC 3
G Nitro engine priming and starting difficulties (needs help) Nitro RC 27
Matty1933 Hpi rush evo engine swap mt2? Stadium Trucks 0
RicoBanderez New exhaust, engine now won’t start - help please Nitro RC 10
L Looking for exhaust that fits Force Engine 15 CNC Engines 11
J New Nitro engine Nitro RC 10
Skippy64 Advice needed about a engine Nitro RC 11
H Need help identifying engine Nitro RC 0
Rubendb The best 1/10 scale nitro engine Engines 47
>BD The most vulnerable rc engine placement. Nitro RC 5
ocrcmec Vintage RB racing engine help Engines 2
Laurent James Engine not starting Nitro RC 6
Laurent James Nitro RC engine will start but dies when I apply throttle Nitro RC 5
BobP Zenoah engine swap RC Boats 0
Sledman3064 Ofna nitro engine Nitro RC 13
leon1355 Glow plug loosens when engine gets warm Nitro RC 6
R JP Eagle R9s old nitro engine - value? Engines 0
S cen mg10 engine replacements Nitro RC 1
Banshee123 Engine tuning issues Nitro RC 3
Ruben GX25RHO engine from go engine Engines 1
A Engine treatment Nitro RC 5
H Force-engine RS17 part Nitro RC 9
M Electric start wont turn engine Nitro RC 5
I HELP! Hyper 7 TQ Engine Problems During Break-in Nitro RC 9
D .15 tmaxx engine fot on an redcat amd??? Nitro RC 6
Cat Revo 3.3 Engine upgrade, which engine mount? Monster Trucks 22
SlydeeRC Nitro engine warmer/heater battery Nitro RC 1
D What engine is this? Engines 8
G Biggest nitro engine Nitro RC 10
