mackdaddy66
RCTalk Champion
I think i'm gettin a bead on it i put two o.s. #8 glow plugs in my savage .25 running 20 percent it turned them both white, but i richened the high speed, ok now i put in a r5 cold and that same truck that was idling good with the #8 wouldnt idle with the r5, ok so if a hot plug in effect advances the timing, then a cold plug retards it in esscence, if thats the case i would need to either richen my lsn or lean it. to get that same truck that runs good with a os #8 to run with a r5 cold what carb adjustments would be necessary. i am out of o.s. 8 plugs, and am trying to learn to tune so please explain if you would. i want to tune my own engines. hpi .25 in a savage xl by the way. please explain if you guys would so i can learn its important to me. and thank you very much
