How much of a turn did you do? Tuning is a learned skill and practice will make it easier. I would suggest bringing it back down to factory spec. Tune the HSN first. Look for a nice stream of smoke and take note of the temperature. Tune for performance first but within reason. For now, try to keep the temps around 220-230. Just so you don't get into too much trouble. Remember, when tuning the HSN, only do 1/4 turns at a time. Run a few passes and take the temp ... just so you don't get too far out of hand and into a lot of trouble. When you have established a good medium, tune the low end.
Test the low end first by doing the pinch test. Pinch the fuel line about an inch away from the fuel inlet nipple. Count how many seconds it takes to die. You're aiming for about 3-5 seconds. If it's more than 5 seconds, you're too rich. Lean out the LSN at 1/8 of a turn. If it's below 3 seconds, you're too lean. Richen the LSN 1/8 of a turn.
The final test is the 20 foot test. From a standing start, let her rip and take note of how it reacts. If it gurgles then clears it's throat, you're too rich. Lean it out SLIGHTLY. 1/16 of a turn at a time till you get a good response. Double check with the pinch test to make sure you're in the general ballpark.
Next test, make a highspeed pass and take note as well. If it dies on the way up to top RPM or hesitates like it's starving for gas, you're too lean. You will need to richen the HSN. If it gurgles on the way down, you're too rich. Make adjustments in 1/4 turn incriments.
I would really suggest getting a temp gauge to keep things in a respectable range till you start to get your tuning skills up. Also remember, tuning can change even in a matter of 2 hrs or less. Keep an eye on performance, smoke and temps as well.
IF you don't have a temp gun yet, do the water test to keep an eye on temps till you get a temp gun. Drop a few drops of water on the head. If it sizzles off right away, it's too hot. If it just sits there, it's too cold. If it sits for a few seconds and then boils away, you're in a good spot.
