fit tires with wheels
guru350
elmont
trying 2 buy knew tires
which tire will fit a rim with these SPECS: Width: 2.2" (56mm)
Diameter: 3.3" (83mm)
tire #1 ........ SPECS Inner bead diameter: (3")77mm
Total outer diameter: (5.5")140mm
Bead width: (1.6")40mm
Total outer width: (3.3")84mm
tire #2...........SPECS: Inside Diameter: 2.2"
Outside Diameter: 3.5"
Width: 2.2"
tire #3 SPECS: Diameter: 146mm (5-3/4")
Inner Diameter: 92mm (3-5/8")
Width: 95mm (3-3/4")
I don't believe any of your choices are correct for your wheel. It's a stretch, but you may be able make tire 1 work. I'd look for a correct tire myself, the inside diameter of the tire should match the wheel diameter.
What brand of wheels do you have and what are you using them on? I am guessing it is a t or e maxx..
