rossb
I finally got a chance to start my new SS for the first time. I first ensured that the two needles were at factory specs. Next I pulled the pressure line off the exhaust and blew into the line to prime the carb. I turned the throttle servo a bit to open the carb about ¼ of the way and then I put my glow igniter on the glow plug. I put the car up on blocks and after 2 quick pulls the motor started up. I then removed the glow igniter. I though to myself that this was way too easy. I spoke too soon.
The RPMs climbed up pretty quickly with the tires spinning. I reached for the throttle servo and tried to turn it down a bit to lower the RPMs and the motor immediately died. After that I put the throttle back to ¼ and tried starting it again and it was very difficult to start. I pulled and pulled a bunch of times and finally it started again. I left the throttle alone and it died very quickly.
I tried starting it again and I felt some resistance on the pull cord. I removed the glow plug, tilted the truck to the side, and gave it about 6 pulls. Some Nitro shot out of the glow plug hole. I put the plug back in and it started on two pulls but quickly died again. I tried starting it again and after about 10 pulls a blister started to form on one of my fingers.
I removed the plug again and tried to clear fuel out of the motor. I put the plug back in and when I pulled the cord the handle came off the cord and parts went flying. The string went back into the pull starter assembly but I found all of the pull starter’s external parts including the little metal plug the cord ties to inside the handle.
I went into my garage and with my blister hurting I pulled the engine and then the pull starter assembly. From the looks of the handle and it’s little plug inside it seems as though the cord just slipped out of the handle without really breaking. I took the cover off the back of the pull starter assembly and retrieved the cord. I threaded the cord through the little black cap, the rubber hose, and then reattached it back to the handle. The pull starter looked good as new with no loss in length. I put the motor back in the truck and the pull starter works fine again. I put some after run oil in the motor and called it a night.
So what happened here? Any ideas why this motor did not want to run?
