EZ Start Help
Tmaxx96
Gone - bye bye.
Willington,CT
My ez start is not working properly the start shaft is new along with the one way bearing is new too can any one help me here is a video of the ez start working thanks for all the help Tmaxx96:)
Here is the link
and if you get a chance check out my other vids to
at the bottom of this page
http://www.youtube.com/normani136
another vid
[ame]http://s494.photobucket.com/albums/rr305/Nathanct_2008/?action=view&current=T-MaxxEZstart.flv[/ame]
sounds like your one-way bearing is dry.... i had this problem with my rustler..... just put a little vaseline in it and try it again.....
Definitely the OWB. It gets oily over time and begins to slip. You need to pull the starter off, remove the bearing and clean it with alcohol. Clean the shaft while you're in there also.
its just dirty, for me it gets full of fuel and crap, i just wash it out with gumout or alcohol and put it back in. after about 3-4 bearing cleans i dissasemble the whole thing, clean it, and re-oil it. i use 1:1 bearing oil.
yeah i fixed it thanx for all the help everyone thanx again TMAXX96
BTW i used wd-40 and carburetor cleaner it work perfect thanx
