I believe the part number was 5338R and they are for the rear toe links or for front steering.
Sounds like alot of fun to me! LOL Your E Revo is going to be stout.
I am also having problems with getting my packs to work correctly... the problem is not the length of the pack, but the way the wires are soldered on. I am running a 7 Cell side by side pack. The wires do not make it to the stock slot for the wires to run out of the pack. and the wire leads are so short off the speedo that the right side packs wires won't reach. Did you have any issues with this? I am guessing I am going to have to dremel a few slots in the battery box doors so that the doors can close around the wires? Thanks man.
Tom
You can always make an extension to lengthen the wires coming out of the speedo.
I would just remove the wires from your packs and solder on some longer ones to suit so you don't have to hack the battery doors.
Do you have a pic of how your wires are soldered on your packs?
That is exactly what I mean regarding the extension. You may be able to fashion one that enables you to snake it down into the battery bays and connect it to the batts inside. There should be enough room above the batts for the wires and connector. If not, there may be enough room where the battery doors bulge outward.
My 7 cell packs are wired the same way. I will see if what I am talking about will work when I get home this evening.
Why not just solder new longer wires onto your packs?
If you have a decent soldering iron with a wide tip, it is a piece of cake.
Practice on some cheap Alkalines until you feel comfortable with doing it.
My procedure:
Clean the ends of the battery with a scotch brite pad or steel wool then wipe it with DA.
Be sure not to touch the ends after cleaning.
Tin the end of the wire and then flatten with some plyers.
Tin the end of the batt.
Put the end of the wire on the tinned end of the batt and press down with the soldering tip.
When you see the solder melt, remove the soldering tip and hold the wire in place until it sets.
That's it.
I use Deans solder so I don't need to use flux. You may need to depending on what you are using.
