Ericke1
What brushless setup will be a direct fit for this
I have mine all ready to race on a tight on-road track.
Stiff springs and shock oil along with Tekno's sway bars makes it stick in the corners. I also put on some 40 series Road Rage tires with a 1/2" offset.
With the stock electrics and two 6-cell nimh packs, I am lighting the tires on take off. I plan on racing it for awhile using two 2S 8000mah lipo packs before adding a brushless set-up.
Honestly, I think the stock motors will work great for the racing I will be doing.
As far a brushless set-ups, I would just go for one of the Novak HV set-ups. It is a proven system that works well.
I am going to use the Mamba ESC and Neu motor because I already have the Neu motor. If I did not, I would get a Novak.
Aside from the Tekno sway bars i added, all my changes are cosmetic such as replacing all the silver rods with the Traxxas red anodized tubes. I do plan on swapping out all the stock arms with the set of RPM arms that are from my nitro Revo only because I already have them.
The rig is perfect right out of the box and no mandatory upgrades are required. You will not be disappointed.
Yes I did. Everything I have is Deans and I wasn't about to switch to Traxxas.
If you do the switch, only cut one plug off and then solder on the Deans to those leads before you cut the other plug off. If you cut both plugs off, you can easily mix up the wires.
I don't have brushless in it yet since I still don't have the single motor mount and cover.
