o0prodigy0o
- Racing
I have a LST1 and just got done doing the LST2 Conversion Kit running the stock LST1 .26 motor. I finished her off last night and figured Id do my test run this morning. I got everything ready to go and I can't get the spin started to engage the motor only at the end of a spin cycle does compression happen. I've had this problem before w this truck but it solved itself easily by just moving the starting stick around until you could hear the compression of the motor. I tore down the spin starter side of the motor and noticed alil wear and tear on the starting pin but other than that everything else seemed ok. I have about 3 1/2- 4 gal through this motor and she hovers in the 210-220 degree range so shes alil rich. Any ideas?
