Engine problems...
Kodama
Alright... I got the carb flipped around and everything hooked up again. But when I go fairly fast and stop the engine revs real high for a few seconds then drops, this happens in both gears. I took my tranny apart a few days ago and got it back together too. But when I went to adjust the 2 speed I didn't see the screws. Did I align it incorrectly? And what should I do about the engine revs?
I retightened the carb pushing down on the carb to reseal the O-ring, if that could be it.
Sounds like a lean condition. I would really check for air leaks after a carb flip. What engine is this? Is it the old Tmaxx .15? By drops do you mean bogs down or does it shut off?
I had a hole in the fuel line. I finally found it when my fuel line ripped where it connected to my fuel filter and sprayed fuel all over the place.
