driving in snow air filter soaked
bluebombersfan
After makeing cardboard covers to protect the airfilter of snow I thought I covered it enough but apperantly not as after using it I noticed the snow still found some way to get to the air filter, I gave it a little squezze and sure enough it absorbed a little water, I'm hoping it didn't work it's way to the carb everything seems to be running okay. is there any ideas out there on how to deal with this problem
Outerwears makes a waterproof cover that you tie over the filter.
IMHO cheap solutions will mean less-than-needed results. If the filter is getting just a tad damp I wouldn't loose sleep over things. If you are soaking the thing then that is a different story.
Cheap solution for me was. Cut Pepsi can the length of air filter. punch hole in the end for the screw, and TADA.
It's a good idea to run an engine you really aren't too worried about wearing out when it's cold. You should throw up some pics White Snake. The pepsi can sounds like a pretty slick idea.
As requested sir.
