Look at what I found! All I did was open up their main page and type in "Starter Box" in the search window and it retured all kinds of starter boxes.pissant said:I was planning to get everything off of towerhobbies.com for my racing buggy, but i can't seem to find a single starter box off of towerhobbies. What could i be doing wrong?
It tells you plain as day what is needed right there to run the box.INCLUDES: One Ofna 1/8 scale On/Off Road Starter Box with, 12V Motor, Battery harness, four rubber non-skid pads, four plastic spacers, four rubber feet, two 4mm x 10mm screws, three 4mm x 5mm screws, four 3mm x 8mm screws, one 4mm x 18mm screw.
REQUIRES: Charger for 12V battery (can use HCAP0200).
12V Battery (HCAP0800)
Then two posts later you say:
I thought that WAS the box that you ALREADY ordered... it looks like you didn't order it or something??? Maybe by that last post that you are still just thinking about ordering one? I am so confused with you.so if i get a starter box i need a battery and charger and i will be set??
