truggy83
I noticed that the right left rear tire of my nitro stampede had a lot more play in it than the other tires. Under hard acceleration it would rotate and shift at an odd angle causing the car to sometimes become unstable or sway back and forth. I took it apart tonight and noticed that it has brass bushings inside that the stub axles fit inside. I always thought there would be bearings in there. I have an extra set of bearings that I am not using and put them in there to see if the bushings were the problem. Replacing the bushings with bearings was enough to correct the problem. Would it do any harm leaving wheel bearings in there instead of bushings? They are both the same size 5x11x4. I was just wonder if it would cause any problems later on down the road using bearings instead.
