Blu_boost
The maxx seems to creep foward slow in the low rpms, then mid-range the power kicks in. Still breaking the engine in. Has power at the half throttle point but the low-end isnt what id like. Probaly 6th tank on the breakn. Clutch adjustment issue? Its a Dynamite .19, seems to be running like a champ. Holds tune really good and starts on first pull with a charged glow igniter. Low speed seems to have a good pinch test, is it too early in the breakin to be expecting good low end?
fyi this isnt like a creep related to high idle or air leak. It idles fine while stationary without any brake, really steady idle.
Edit: I just noticed there is alot of play in the linkage, before the carb even opens. Ill run it in the morning to see if it helped.
