Mr Nice Guy
Well I tore my tranny apart and put the shift point adj screw back in (it had come out and was jamming the hub) and put everything back together. When I ran it I noticed that it now didn't want to engage the clutch untill I had the throttle at almost 3/4. When it did engage it sounds like it pops into gear all of the sudden and then takes off pretty good. Once going it never seems to shift. The only time I had it shifting is before I leaned out the needle valve (I bought it used and ran it with the settings that the previous owner had left which were very rich) and even then it would take a long time to shift. When I put it together I set the screw at 6 1/2 turns out like someone had suggested as a good base adjustment. I tried to loosen it an 1/8 of a turn at a time but it never shifted. I didn't want the screw to fall out so I quit loosening it after another full turn. I then tried tightening it to about 5 1/2 turns but that had no effect either. Now when I had the tranny apart everything looked good. There was only one thing that I noticed that was wrong. On the fork that changes forward/reverse it has two little bushing/peg things on the ends where it actually contacts the hub. One of these was broken (I found it in the bottom of the case) I'm thinking this is possibly why it's taking so long to engage. Maybe it's not moving all the way into position. Any thoughts on this? Also I can't figure out the shifting either. This is getting a little frustrating. I just want my truck to run. Sorry this is so long but I wanted to give as many details as possible. Any help will be greatly apreciated. Thanks in advance
