Carbi help
GodsGr8st24
Good Evening guys and gals I need some help, I have a GS Racing 1/10 scale car with a GS15 engine. I can get it to start with some fuel in the carbi and it will idle until the fuel runs out of the carbi then it stops. I have cleaned the carbi so that it is free flowing and I Can push fuel through the line. I feel as though it is not sucking fuel through the line. Could this be true? Or does anyone have a different theory. Please help cheers
Need some info probably first.
Is this your first nitro RC?
Is this a new RC?
Does your tank have a built in filter?
Is the engine side exhaust or rear exhaust?
If you disconnect the pressure line from the tank and have it connected to the pipe, can you blow into it and hear the air come through the pipe?
If you disconnect the pressure line from the pipe and have it connected to the tank, can you blow into it and hear the air come through the tank?
If you disconnect the fuel line from the tank and have it connected to the engine, open the throttle then blow into it and hear the air come through the carb?
If you disconnect the fuel line from the carb and have it connected to the tank, then blow into it and hear the air come through the tank?
Have you checked your gap? It should be about 1 mm
D
Replies
12
Denver
D
S
Replies
5
tudordewolf
tudordewolf
E
Replies
9
3K
EJMOPAR70
EJMOPAR70
yfzracer450
Replies
3
TRAT
