carb stuck, want to kick savage!
pitbull14218
Buffalo
ok I took the screw out so I can remove the carb from my truck and the carb won't come off the motor, I can turn the carb but it won't come off help!!! what's the trick
is there just a nut you loosen if so you have to tap the nut in. loosen the nut and tap it in with the end of a screw driver not hard and it should come.
I popped it off but the bottom part of the carb neck had a lip I cracked it a little while popping it off... I sealed the carb to the motor with RTV but I don't really want to wait 24hours for it to harden. The rtv package didn't have a wait time so idk I might start her up since I doubt this will solve my tuning. Issues
Not waiting for the rtv to cure is probably going to lead to more problems then you already have. You don't want it getting into the engine.
Hmm might wait then, thx for the advice I didn't think it would get in for some reason
ccater1026
Replies
1
Nitroman7888##
Nitroman7888##
ccater1026
Replies
15
Nitroman7888##
Nitroman7888##
S
Replies
5
tudordewolf
tudordewolf
E
Replies
16
1K
easy rider
E
