Hi i have quite a few revos (5) only ones brushless and many other electric/nitro rcs, but the one i been runnin in the snow has the old 2.5r in it, god only knows how old it is i can see mar marks all over inside the block from someone inexperienced changing out bearings, had an extra piston and sleave so put it in all was perfect till now, it will run perfect at 5 turns out at 25 degrees Fahrenheit but its on the lean side where its pulling wheelies, trouble is few minutes into a tank it gets hot and i tried turning out to 6 turns and it got leaner! Took engine apart cleaned and disassembled carb, had some dirt in it but i noticed the one way shaft in the backplate had a bit of play, i had a brand new one from an engine that got cracked and it had no play in it, could this have veen my problem? I set the hsn at 4 turns out assembled everything and will try it tomorrow, i have a few new 2.5s but i like to run them till the bearings go then i use em for parts and toss in the new engine, checked fuel lines and tank, in my many years doing this (started running nitro rcs by myself and tuning at 7) i never had this happen but only once a similar case, on a pro.15 t maxx i bent the hsn but it was a bit different than what I have here, thanks in advance and sorry for any improper grammer, trying to get better at it! Anyways hope everyone has a great day, burnt flowers fallen, TypeONegative
