Broken charger
Kyle
Hey so both of my wires for my ec3 charger broke of and I was wondering If it matters how I Solder them back on. Thanks lmk
You have got to have positive to positive and negative to negative or red red and black and black. If you have a multimeter you can put it on and it will tell you what direction your flow is. If you put the negative on the positive side it will show a negative voltage. If it's hooked up properly it will show a positive voltage
It’s on the charger side not the battery side. There is no red or black on the wire that I can see.
Id go and replace the wires from the inside out ..is this a ac charger or are those dc? if ac id still replace from circuit board or internal power supply out.. those wire look rough what abuse have they gone thru? 220volt or 115v or 12v ?
