Big rock lvc voltage
Caleb90
Up state
So i have noticed i get more run time out of my rival mt10 vs my big rock. Either the big rock draws more current or the lvc is higher. These are what i got today after running two 2s packs through. Normal? Next time i run the rival i will document to compare
lvc is to low of voltage should be at 7.6... if invest in a battery buzzer that way it will go off when voltage hits low voltage.
Umm yea what they said
Its set at how it came from the factory
I didnt think the blx100 lvc was adjustable.
Lvc for the blx100 is 3.4v, so its right where its supposed to be. So i am not getting how i am too low
its not normal you have been told the correct lvc why dont you understand whats been posted.7.6 divided by 2 ..3.8 for a 2nd grader,,
3.8v/cell is storage charge values. I don't know why you would want to cutoff your runs at 3.8v/cell, unless you just don't like to storage charge your LiPo's when done running. There's no need to stop running your LiPo's at 3.8v/cell. I run my LVC around 3.4v-3.6v/cell. It just depends on the ESC and what settings it allows. So "the correct" LVC is wherever the user wants to run it.
3.8 is storage voltage. From what i read you dont want to go under 3 volts. So any thing from 3.2-3.6 is fine. Its a simple question. No need to get pissy
Big rock just must draw more voltage and amps. As the rival has a higher cut off, but longer run time
C
Replies
11
2K
Caleb90
C
C
Replies
7
3K
NicJames
NicJames
E
Replies
3
Ramp addict
Ramp addict
C
Replies
27
3K
Caleb90
C
partsmgr
Replies
4
luke66
luke66
