Z400
Gone - bye bye.
Well here it is, make offers.
i will be listing prices for everything within the next couple of days.
Thanks
COMPLETELY PARTING THIS TRUCK OUT
Also in search of a Futaba FAAST radio set up, just let me know what you've got if you have something you want to get rid of
Parts Currently Installed-
BRAND NEW PARTS-
Vantage V-Armor in silver, $20
Tekno receiver box, modded, $7
Traxxas hard anodized shocks, $50
Orange and green springs, $3 each
Losi 8T tank, $8
Himoto V2 wing, $9
CRT .5 header and pipe, $30
RD logics turnbuckles, $19
Lunsford p2 titanium push rods, $28
RC Screws Stainless screw kit/ majority are polished- $15
Dynamite counter sunk washer/ blue and silver-$2
Front body posts and mount, $3
P2 rockers dyed black, $5
Diffs front and rear, $23
Front bulk heads, $11
Rear bulk heads, $11
Proline steering arm, $8
Team Losi Pipe hanger mount, $2
3racing engine mount(part that attaches to engine), $9
RD Racing blue aluminum rear shock mount, $10
ProTek rc wheel bearings all around, $9
OuterWears green pre filter for air filter, $8
Qoncepts chassis brace, $13
1 new drive shaft, $7
Center shafts, $2
Pivot balls, $9
Traxxas aluminum pillow balls, $18
rear pivot ball dust boots. $3
Custom rear body post mount brace, FREE
Lunsford Titanium hinge pins, $17
Brand New Jconcepts Tango body, Custom painted, $53
USED PARTS INSTALLED-
Front traxxas arms, $6
Rear RPM arms, $13
Axle carriers, $10
3 drive shafts, $9
Flywheel and clutch set up, $14
OS .18TM with less then 1 gallon converted to bump start, $100
MS air filter, $11
Front shock mount, $1
Front bumper mount, $1
Hobao hyper 8 bumper,modded, $2
Rear body posts and mount, $3
Front and rear skid plates, $3
Front bulkhead aluminum tie bar. $3
Racers edge 14t clutch bell, $6
Blue Groove Concepts 17mm 241 super wides with Panther tires, $45
Blue Groove Concepts 17mm hubs, $12
Spektrum DX 3.0 with brand new antenna, $100
Extra Parts I Have-
NIP lunsford titanium hinge pins, $20
NIP wide ratio gear set, $5
NIP traxxas chassis brace, $5
NIP maximizer composite 17mm hexes, $3.50
NIP shock rebuild kit(3 packs), $3.50 each
NIP FOC, $9
NIP front and rear skid plates, $5
NIP servo saver mount and steering arm stop, $2
used center skid, $1
used 2 rear upper arms, $3
used 1 rear lower arm, $1
used 1 front upper arm, $1
New front bulk heads, $12
used lot of stock hinge pins, push rods and turnbuckles, $8
LOTS of brand new AvidProTek and Stock Bearings, $45
used tan and gold springs, $5 for all 4
spare rockers, $2
New front skid plate set, $2
2 traxxas 1100 mah flat receiver packs, 1 new 1 used, $12 each
Brand New 40t spur gear, $2
Clutch Bells,
2 1/8 clutcheblls- 1 18t and 1 15t, Both BRAND NEW, $7 each
3 Traxxas clutchbells, 1 20t, 1 18t, and 1 14t, ALL BRAND NEW, $7 each
USED Racers Edge 19t, NEW Racers edge 14t, $5 used, $7 new
New slipper rebuild kit, $5
used slipper parts, $2
used/new exhaust couplers/ deflectors, $5
lots of axle pins/ wheel nuts/ 14mm hexes, $6
1 used set of maximizer 17mm composite hexes, $2
LOTS of shock parts, retainers/caps, pillow balls,rocker posts, $15
2 outer drive shafts, $7
1 Stock OWB, 4 HPI OWB's, 2 BRAND NEW HPI OWB's, Contact Me
Ching Chang Japan New OS .18Tm sleeve resizer/pincher with instructions, $15
CRT .5 pipe and header, $30
HEAVILY polished, very shiny stock pipe, $10
CRT .5 header, $11
USED THS maxx pipe, ran this on my revo for MANY gallons, it is very beat up $7
2 OS .18TM's, both brand new, $150 each
Sirio .18TX brand new, $110
Brand new Proline bowties mounted on Losi yellow 17mm dish wheels with offset, Ofna orange molded foams(all brand new). $55
Brand new Proline Crime Fighter MTRs with MTR foams mounted on yellow 17mm full offset wheels(all brand new), $55
Brand new Proline Crime Fighter MTRs with MTR foams mounted on white Losi 17mm dish wheels with off set(all brand new), $55
Brand new Proline Hole Shot MTRs with MTR foams mounted on Losi white 17mm dish wheels with off set (all brand new), $55
Parts SOLD-
Vantage 3.3 Chassis SOLD
Tekno throttle linkage set up/ modded SOLD
Traxxas sway bars SOLD
Traxxas wing mount, SOLD
Golden Horizons blue and silver aluminum shock ends, SOLD
Traxxas Heavy Duty servo saver spring, SOLD
Extreme racing carbon fiber brake disc, SOLD
Extreme racing rear tie bar SOLD
Custom battery mount SOLD
Custom tank mount SOLD
Wide Ratio gears, SOLD
3.3 transmission with FOC, SOLD
Traxxas chassis brace SOLD
Custom carbon fiber wing mount tie bar, SOLD
AMB Transponder missing 1 mounting tab SOLD
Brake linkages, SOLD
Slipper clutch, SOLD
Center Diff, SOLD
Rear brake, SOLD
Spektrum SR3000 receiver, SOLD
few axle yokes,SOLD
couple stub axles,SOLD
Used Proline Crime fighter MTRs SOLD
Resonator dual chamber pipe, SOLD
Tango Body, unmounted, brand new paint. SOLD
Tekno throttle mount SOLD
Associated factory team NTC3 starter box with Native Racing Conversion for REVO, SOLD
5 axle carriers, some new, SOLD
38t spur gear, SOLD
HPI Roto Start, SOLD
NEW PICTURES-
Stock pipe with CRT .5 header
Thanks
BRAND NEW PARTS-
Losi 8T tank, $8
Himoto V2 wing, $9
Center shafts, $2
Pivot balls, $9
Rear RPM arms, $13
Axle carriers, $10
3 drive shafts, $9
MS air filter, $11
Extra Parts I Have-
NIP FOC, $9
spare rockers, $2
Clutch Bells,
CRT .5 header, $11
Parts SOLD-
Center Diff, SOLD
Rear brake, SOLD
few axle yokes,SOLD
38t spur gear, SOLD
NEW PICTURES-
