Zulu504
For 132ft drag racing, is it best to gear for faster acceleration or for higher top speed?
Spot on. Drag racers always say torque is where it's at. That is, as long as you can hook up. So go with the lowest gear you can, without spinning the tires. I'm not an RC drag racer though, so just basing that on my old drag racing days.Depends on your personal goals, Zulu.
Drag racing is a contest of acceleration. Speed is just something that happens along the way.
That said, any discussion about drag racing always seems to migrate to speed. At least on the RC side of the house anyway. That can serve as a point of confusion for a newcomer. E.T. (Elapsed Time) wins races. Speed garners bragging rights.
Zulu, you've landed in a highly challenging and rewarding part of the RC hobby. Good luck and Cheers. 'AC'
ThanksNot too familiar with drag racing but with bashing the higher the pinion the higher the speed. The lower the pinion the less strain on the motor and lower speed a little. I only had experience with 16 to 23 tooth pinions and 83 to 90 tooth spurs. I've seen people use like 30 tooth pinions and 50 tooth spurs for speed runs.
ThanksYour gearing is something that has to be tuned or dial in. Your final gearing is going to be dependent on a ton of factors. Motor, ESC, ESC & Motor settings, rollout, the list goes on.
Thank youSpot on. Drag racers always say torque is where it's at. That is, as long as you can hook up. So go with the lowest gear you can, without spinning the tires. I'm not an RC drag racer though, so just basing that on my old drag racing days.
ThanksDepends on your personal goals, Zulu.
Awesome, thanks.Spot on. Drag racers always say torque is where it's at. That is, as long as you can hook up. So go with the lowest gear you can, without spinning the tires. I'm not an RC drag racer though, so just basing that on my old drag racing days.
