battery and charger suggestions..
maxxmasher8
ok i alredy mad e asearch so please dont gripe at me. i am getting a rc18mt and i want suggestions on what li-poly battery and charger combo to get. my limit i would want to spend would be around 130 and i also dont really need a high dollar charger either unless it is just absolutely necessary!
thanks,
tyler
I can't give you an answer, but I want to make a comment....
This is a very relavant question that has not been disgused (sp) on this forum. The comments in the past week were directed to afew individuals and for the most part problems have been fixed. You will not get any flack from any members for asking questions, just use your judgement when posting and you won't have any problems here! I promise!
If you get LiPo batteries, Don't cheap out on the charger...if you overheat LiPo batts they are flamable....get a charger w/ the temp sensor...If you can't do both get the better charger and lesser battery...you can always go get the better battery later on.....
could someone give me a link to a kind of charger that plaidfish is talking about.
thanks,
tyler
Duratrax Ice: http://www.southeastrc.com/item/DTXP4170
Great Planes triton: http://www.southeastrc.com/item/GPMM3150
I got the Ice but I think the triton would actually be a better charger for me.....it does up to 20 cells...the Ice does 10......the Ice has a motor break in feature for electrics.....when I got mine I thought I'd be getting more into electrics but I'm pretty much a Nitro addict...
Actually there is a lot of new info coming out on LiPo charging.
I’m catching bits and pieces of info as time goes on. Here is what I understand to date.
Each cell in a LiPo needs to be charged and monitored separately. If you have a 2 cell battery you need a charger and a battery setup that will address each cell independently from the other. There are LiPo chargers on the market that have 3 independent chargers in one unit. If the cells are charged as 1 unit the cell that is the weakest and charges the fastest will over heat before the other(s) are properly charged. Charging the PACK as 1 unit is not recommended.
I will find some links on this subject and post them here. This subject has caught my eye and I’m trying to learn as much about it as I can. It’s my belief that this technology is where the hobby is headed,
I can't seem to find the links on this computer. They must be on my other one. Here is a tid bit I found in a doc I saved.
Charging methods for RC Lithium Polymer Packs
1.
Traditional: A charger will charge an entire RC Lithium Polymer Pack either 2 cells, 3 cells, or 4 cells pack. Because cells in each pack are series connected together, an electric current will flow from one Polymer cell to the next. The cells in each pack will receive the same amount of current.
There is a potential problem for this charging method. Because cells may have different internal resistance or slightly different capacities, each cell may require different amount of charging. However, if cells are getting equal amount of charge, some cells will be under-charged and some cells be over-charged. For over-charging a cell, the cell will get damaged and its internal resistance will increase and capacity decrease. This cell will then be susceptible to further more serious over-charged when charge again in series with another healthy cell. This creates a vicious cycle to damage one cell in a 2, 3 or 4 cell pack. When a single cell gets damaged to a certain condition, the entire Lithium Polymer pack will need to be replaced.
2. Safety Charging: (A battery pack needs to have special wiring)
A charger will monitor each cell in a Lithium Polymer Packs. Each cell is individually monitored so that no cell will be affected by other cell physical or chemical conditions. When one cell in a pack reaches the maximum voltage (4.25V), the charging will be stopped and no cell will be overcharged. This is to ensure that all cells in a lithium polymer pack will stay at a healthy condition after hundreds of charging cycle!
In order for safety charging, a Lithium Polymer battery pack needs to be specially wired. Each battery pack will have two wires coming out of a pack. One is for discharging and one is for charging purposes. The discharging wire series connects all lithium polymer cells and charging wire parallel connects lithium polymer batteries. This is the next generation advanced charging method. This advanced charging has been employed in electric cars where battery packs are expensive.
Furthermore, one can use the discharging (series connected) wire to do all charging and discharging. This lithium polymer pack will then behave just like a traditional lithium polymer pack. For advanced lithium polymer charger where individual charging is available, it also can do a traditional charging!
Here is way to much info that no one can understand
http://www.eetasia.com/ARTICLES/2004DEC/A/2004DEC15_POW_AN.PDF
The Great Planes Triton is a good charger and will charge everything. its easy to set up and program, and it will accept a thermal probe sold sep. I ran across an add not too long ago about a dual wired poly pack with the built in cut off per cell. I think it was on RC univers, but I'm not 100% sure on that. I'm too involved in Nitro's now to worry about electic stuff. lol
Hello.
I just purchased two rc helicopters. One Honeybee King 2 and one Cyclone Skyhawk. The instructions on charging the batteries is not very clear. Does anyone know how long to charge an E-Sky 11.1v 1000mAh 3 cell LI-Po battery? No laughing. The other battery for the Skyhawk says 2 hours. It is 9.6v-700mAh. I'd be very gratefull for input on this.
Thanks,
Steve
Well, if you have the same kind of battery as I happen to have for sale (shameless plug), it takes roughly about an hour and a half to charge at about .8A. The charge time varies depending on the current supplied by the charger.
The 9.6 battery (most likely a nimh pack), again depending on charger output current, could take anywhere from an hour and a half, to 10 hours.
