balance that boat
nitrofish
RCNT Rookie
if you are having problems with the handling of your boat- try this- buy a ballast tube 1/4 inch in diameter and long enough to fit in the forward bulkheads of the bow. add b-b"s into the ballast tube until you get the desired handling you need. i use a pencil erasure to plug the ends of tube after i have used epoxy to keep these little balls from rolling around. by removing or adding b-b"s- you can trim that boat right up to par. be sure to check the correct place of your boat for center of gravity.
