SteelCityNitro
I just got the Security Defender Virus this morning. I've been fooling around with this bastard all day, and can't seem to get rid of it. If I start up in safe mode, the virus is disabled. My antivirus program was able to remover some of the files, but the program still runs and annoys me.
here's what I've found about this virus:
Just the latest spawn in a large brood of fake antivirus scanners, Security Defender has numerous connections to earlier forms of rogue malware and should be removed at the earliest opportunity. Like other rogues, it operates by way of a simple graphical shell that pretends to alert the user to serious computer errors. However, these are all false, specifically created to be a scam.
A Biography of the Newest Member of the Nasty Rogue Family
Security Defender, despite being the 2011 model of the same old scam, shares the limitations of these rogues. Most importantly, it's completely unable of detecting or removing true threats to your computer's stability or security. Like many kinds of malware, it has its origins in the Russian Federation. Although it may look a little different from others, more polished and modern, its methodology is identical. This is good for the user, because it means that removing Security Defender is an already solved puzzle!
Identifying the Traitor in Your Ranks
Sometimes it can be difficult to tell whether you have a malware infection on your computer. Security Defender is happily a standout rogue that makes identification very easy. In fact, it can't wait to advertise its presence! It will run itself automatically rather than requiring a prompt, and will immediately detect many nonexistent threats. Despite these messages, Security Defender is physically incapable of actually scanning your computer, let alone removing serious threats, even in its supposed 'full' version.
Another ironic trait that makes Security Defender a snap to identify is its rather morbidly enthusiastic marketing. This is a rogue that truly relies on you not knowing what it is to get the sale! It will engage in tactics such as creating popups or modifying your browser settings with a proxy server for redirection. Whatever foul tactics Security Defender takes always ends at the same goal, towards a purchase form for itself.
The Worst Security Defender Has to Offer to Your System
Security Defender's aggressive attempts to protect itself from being deleted are both its most blatant and its most dangerous behavior. To this end, it may automatically shut down any process it considers a threat to its own predatory well-being, including various genuine anti-malware scanner programs.
The Achilles Heels in Security Defender
Even in the face of such aggression, there's no reason to give in to this rogue invader. Security Defender has several weak points that make it easy to remove. Because it requires a web browser to scam you out of your money in the first place, Security Defender won't block the processes for Internet Explorer or Firefox.
However, it's usually more efficient to boot into Safe Mode. To access the menu for Safe Mode, simply hit F8 while starting your computer and this will prevent Security Defender from starting up in the first place. If your Internet connection is for some reason cut off or crippled by this rogue, there are two ways to regain it. The first is to use 'Safe Mode with Networking.' The second works in any mode - just disable proxy servers in your LAN Settings under the Connections tab of Internet Options (found in the Control Panel).
While in Safe Mode, removing Security Defender and any other infections should be your top concern, since this nasty little guy will hinder all other operations as long as it's on your hard drive. Some professional anti-malware scanners may have difficulty recognizing and cleansing the PC from Security Defender. It can also be removed in a hands-on fashion - searching for all its files and folders as well as registry entries, and deleting them one at a time. With this last method, you should take care that all components of Security Defender are truly deleted. Make sure that there aren't any malware-based processes running during your deletion sweep! If done properly, your system should be free of this highly disruptive pest, allowing you to go about your life with renewed freedom.
Security Defender or SecurityDefender Automatic Detection (Recommended)
I can't seem to locate any files related to this damn thing. Where should I be looking?
