after run procedure after being in the snow
Tarant
Medford
I got a lot of snow here and I was wondering do u do anything different in the arp due to the snow or would it just be the same thing as normal
With my electrics I look for any sign of water (usually with the blow dryer in one hand).
After you run in the snow, the first thing is to get as much of the heavy snow off as you can. Then if you have an air compressor, use it to blow off the rest of the snow and water. Use a hair dryer or heat gun to dry the rest. When you're done with that, make sure you oil up your bearings and anything else that might rust.
Get any remaining snow off and blow the truck off with compressed air. Give it a good dusting with WD-40 when your done, it will prevent rust and should help displace any water hiding out in unwanted places. Lube bearings and such afterwards.
