AE xp2 controller. Micro fail-save & steering
street silence
RCTalk Champion
What’s up guys I’m back with a new & bigger engine on my new chassis. I’m having a bit of an issue I have a video to kinda see. My steering problem, I have a micro fail-save installed at the Beginning it was working fine till I started fixing my steering that happened where my car locks up when I steer. I have my fail-save on the throttle channel.
Replace the receiver batteries. I bet they are bad? Low voltage kicked in.
That’s a dirt cheap fail-safe
Is it possible to do a lipo battery or dynamite battery instead?
Problem solved!! Lol thanks fam this alkalines don’t last at all
They last ok in the transmitter, but not very long for receiver/servo use.
I use 2/3A NiMH hump or flat packs in my nitro's.
https://www.amazon.com/Tenergy-1600mAh-Double-Battery-Connector/dp/B078NJQF4T
Helpful to have a switch with a charge jack, if you can mount it somewhere:
https://www.amazon.com/DGZZI-Connectors-Accessory-Receiver-Accessories/dp/B07SL2D6BC
Or one with a charging pigtail that you can tuck out of the way:
https://www.amazon.com/Receiver-Battery-Charger-Connector-80579/dp/B001PQRHA4
Does that switch replace the stock one?
I use 2600 Nimh AA cell packs for all my 1/8 and tmaxx. 5000 nimh c cells for gas. Those 1600 2/3 packs I can get for $9 each for my rc10gt
3 way switches https://www.ebay.com/itm/Apex-RC-Pr...e=STRK:MEBIDX:IT&_trksid=p2060353.m1438.l2649
Would I be able to connect a underglow wire on that pigtail, would it work
I have a 2 channel tc-3 have nowhere to connect them I just have them on rn
Yes.
No. It's a 2 position switch. When it's "off", there's a connection between the pigtail and the battery pack. When the switch is "on", there's a connection between the battery pack and receiver. You would need a splitter or something at the receiver to have an extra power connection when the switch is on. Like this:
https://www.amazon.com/Spektrum-Futaba-Harness-Splitter-Airplane/dp/B07PHDYZXN
Mrgoodwrench35
Replies
11
1K
Mrgoodwrench35
Mrgoodwrench35
Nightcrawler67
Replies
4
Nightcrawler67
Nightcrawler67
T
Replies
7
DrFranz
DrFranz
Mrgoodwrench35
Replies
12
Mrgoodwrench35
Mrgoodwrench35
D
Replies
4
WickedFog
WickedFog
