Accelerator Jams at full throttle
Pearforth
Hi all
I am now chief mechanic to my my Grandsons latest hobby nitro cars which he received a Schumacher Swift 2 for Christmas. This car has been a problem from day 1 when the pull starter broke a spring which I managed to repair to keep things going, unfortunately the spring did break again but not before a major calamity occurred when the throttle jammed on and car went straight through a substantial timber gate at full speed. We have now lost considerable confidence in the control of this car and my question to the forum is has anyone encountered similar problems and what do we do to put it right. I have tested the batteries and they each have 1.4 volts + , plus I have done some running test on a wooden block firstly testing all the controls without the engine running which they worked perfectly. With engine running the servo unit seemed to have a mind of it's own when the engine was revved up it just went straight to full throttle and refused all attempts to push it back the only thing that worked was to stop the engine at which time the throttle went back to normal.
reighard53
RCNT Champion
south jordan
Bashing
did you adjust the throttle trim?
could be the batterys in the controller. it happened to my 18mt
also there could be an interference in the radio try switching the crystals in the reciever and transmitter.
flm_savage
Hardcore RCNT User
Military Veteran
Houston, Tx
Bashing
so when you had it on a test bench and cranked up the engine, it still went to 100%?
what radio gear are you using?
beason
Bash, Fix, Repeat..
Webster, TX
Bashing
i had a buggy that would do something similar. It was a bluebird servo and when the rig was running it would start acting stupid. fried 2 receivers before i figured out it was the servo. the vibration of the engine running is causing it to glitch.
Candyman
'Cuse is in the house!
Syracuse, NY
There could be a few reasons for this. But the 2 things I would check first are the servo travel and the throttle linkage. Turn the radio equipment on and just cycle the throttle. Watch the linkage and servo horn when you get near full throttle. Look to see if there's any unusual hitches in the movement when you get near full. There may be a chance that the servo continues to try to push even after the carb is fully open, and sometimes that can bind the servo so it won't easily return. If the radio has End Point Adjustment, adjust it so that the maximum throttle throw occurs exactly when the carb is fully open.
Also, how far away from you was the car when it took off? It may be possible that there was a radio glitch, interference or temporary loss of signal. That can send a rig running off at full throttle.
Ultimately, this is a good example for all of us and immediately shows us all the need for a Throttle Return Spring and a Failsafe.
EDIT: Just read a little more of your post. If the servo starts freaking out when the car's running, it may be an RF glitch. The most common cause of this on a nitro car is metal vibrating against metal. See if there are any places where metal chassis plates may be rubbing against screwheads or anything like that. Try to run out as much of the receiver antenna as you can through the antenna tube. That will limit it's possible susceptibility to the RF stuff. But ultimately see if there's some metal rubbing somewhere.
Pearforth
Sticking throttle at full revs.
Many thanks to all those who answered my question on the sticking throttle at full revs and the ideas put forward that might find a solution to the problem. As yet I haveN'T had a chance to make any further progress but when I have I will report back with the results.
The question asked about what type of radio control equipment is being used it is Response SW 27 MHz.
The other question on how far away was the control from the car when it went wrong it was about one metre which rules out the problem of long distance radio control.
Any more ideas keep them coming they all help.
RC Addict
RCNT VIP
In and out of my mind.
Bashing
Like Candyman said: A failsafe is a MUST. If you don't have one yet GET ONE immediately. Radio interference may not be the cause of your problems right now (but I am willing to bet you it IS) but no one should run without one. I know from experience!
Rolex
Hoof Hearted
Staff member
Military Veteran
In my recliner
Bashing, Flying
Candyman is also correct about the chance of binding if the servo linkage exceeds the needed distance. That's the first thing you should check. Do a lot of testing with the rx and tx on, but the engine off, till you can locate the cause of the problem.
If it doesn't have a problem with the engine off, then you have vibrating metal, loose crystal or bad connection in the receiver.
qaart
Gone - bye bye.
east texas
Bashing, Racing
my ofna car would go 50 feet and start doing this. the car ran away 5 times at least
i bought a traxxas rx and tx works great
Create an account or login to comment
You must be a member in order to leave a comment
Create account
Create an account on our community. It's easy!
Log in
Already have an account? Log in here.
Thread starter Similar threads Forum Replies Date
B Throttle sometimes jams wide open @#(@ Traxxas Revo 3
NurturantQuasar Monster slash 4x4 destroys spur when full throttle from stand still Electric RC 3
B KE25 revs to full throttle after starting (newb needs help) Nitro RC 7
M Almost full 3D PRINTED RC car 1/10th scale with servo suspension RC Builds and Projects 5
W T maxx 3.3 full throttle after 30 seconds idle Nitro RC 5
B Random Full Revs Nitro RC 8
D My rc nitro hpi rs4 dies when close to full speed any ideas? Nitro RC 16
Y Turns to the right and immediately turns full left and back to center Electric RC 6
B What is the full list of ways a company can go out of business Traxxas X-Maxx 31
B How Tough is the Losi Super Rock Rey (Full Version) Electric RC 17
E Traxxas Rustler intermittent full throttle Electric RC 5
2GMitsubishi Volcano S30 2-Speed Transmission Install "Full Setup" Chassis & Drivetrain 5
WoodiE SR-71 Blackbird Full Air Force Version RC Aircraft 11
barneyz71 Need help with Maxx just turning full at rendom Traxxas T-Maxx 18
Huggybear87 New full scale toy... General Chaos 7
Lethal My revo 3.3 is not getting full power.. Traxxas Revo 8
N HPI savage X 4.6 keeps stalling when full gas HPI Savage 1
D savage x 4.6 full throttle stalling HPI Savage 14
godale03 PM Inbox full message General Chaos 13
WoodiE Operation "Firm but Fair" is now in full force General Chaos 9
I can't get my new RC Car tuned. Runs full throttle when started. Nitro RC 19
D can't go full throttle Nitro RC 2
J T Maxx 2.5 Boggs and dies at full throttle Traxxas T-Maxx 3
R Car runs full throttle when starting Nitro RC 13
Buey36 gutted hit a curb at full speed Nitro RC 37
P engine bogging at full throttle Chassis & Drivetrain 7
SSX 2 stroke full synthetic mix Chassis & Drivetrain 16
S Full aluminum kits? Traxxas T-Maxx 6
Lessen My full scale project General Chaos 15
M How can I completely modify a tamiya tt-01 Type-E to its full potential? Electric RC 2
M Kyosho Fw05 cuts in and out full throttle Nitro RC 0
HPI-Killer Servo: Full Turn 1 Way, Little Turn Other Way?? Electric RC 6
N My Xray 808 full story... Nitro RC 6
E Transmitter stuck at full throttle Traxxas T-Maxx 4
N engine cutts out after about 3 mins, and cutts out at full revs Chassis & Drivetrain 7
Gummybear13 Proper full RC breakin procedure Chassis & Drivetrain 11
WoodiE Proline Volkswagen Full Fender Baja Bug Paint & Body 6
S Won't idle well on full tank, idles great when theres less fuel Traxxas Revo 4
rak12 only turns right and full throttle Traxxas T-Maxx 5
T T-Maxx boggs at full throttle? Traxxas T-Maxx 10
M esc cuts out at full throttle Electric RC 12
L Nitro engine full throttle from start Chassis & Drivetrain 2
Jmacca How full should diffs be? Nitro RC 20
M Not full throttle? Chassis & Drivetrain 7
B Your other full sized toys General Chaos 14
E T-maxx 2.3 to 3.3 full conversion please help Traxxas T-Maxx 14
J Full Force R/C Skid plates for Revo VXL Review & Pics Mini & Micro RC 9
S Savage stays at full throtle HPI Savage 16
S Drive train locked up at full throtle Nitro RC 1
D full size rock racers RC Rock Crawlers 7
