Nights1000
Florida
Ok so when I pull up info to see the difference--everyone says the the 5309 is the older model--
Traxxas web page has it the other way .. the 5309 with the 2.4ghz is larger and newer?
I guess I'm just lost on this one--
so why do they refer to the 5309 as the new model that is larger then the previous revo ? and the 5309 is the 2009 model?
further supports that 5309 is the newest model of the revo--
http://www.hoeco.org/modellbau_news/Press release/2008.06 TRAXXAS 5308 New Revo 3.3.pdf
this link shows the 5308 --- in 2008 release date?
Yeah, the 5309 was released before the 5308 originally. You'd think they would go down to 5307.
Revo Family
The Revo family consists of several models originally based around the Revo.
[edit] Revo
The Revo was introduced in 2004 as a complete redesign of a monster truck chassis with a more advanced and reliable design than the T-Maxx. The Revo has become popular in racing, and is also well suited to "bashing" environments such as a backyard or a construction site. Notable characteristics include the inboard pushrod suspension system with new "GTR" shocks and springs, a complex "monocoque"-type aluminum chassis which lowers the vehicle's center of gravity, a stronger transmission that features electronically controlled reverse, sealed limited slip differentials, rubber sealed pivot balls, drive shafts and ball bearings, 3.8 inch wheels and all-terrain style "Talon" tires, and an updated version of Traxxas' TRX 2.5 engine, the TRX 2.5R. It has a claimed top speed of 40+MPH.[8]
A new Revo version was launched alongside the T-Maxx 3.3 in 2006, with Traxxas' new, more powerful TRX 3.3 engine. Because of the demands of Revo owners, the chassis was lengthened 30 mm for more stability, and the motor mount area was braced to prevent it from bending. Other minor changes included a longer version of the body with a new paint scheme to accompany the wheelbase stretch, and new wheels. New add-on upgrades were released, including a center differential, that helps transfer power between the front and rear differentials to increase handling, and a rear-braking module that must be used with the center-differential. It has claimed top speed of 45+MPH.[9]
In April 2008 Traxxas released the limited edition Revo Platinum. It came stock with most of Traxxas upgrades and tuning parts normally available as accessories for the standard Revo 3.3. It was intended as a factory racing version of the standard Revo 3.3.
Later in 2008 Traxxas released a revised version of the Revo 3.3. It incorporated some of the features seen on the Revo platinum, including a polished "Resonator" dual chamber exhaust pipe, dual stage air filter, larger 150cc fuel tank, teflon coated aluminum "GTR" shocks with titanium nitride shafts, 17 mm splined wheel hubs. As is typical of a new Traxxas model, the revised Revo 3.3 received a new paint scheme.[10] #5308
In July 2009 Traxxas introduced a further revised Revo 3.3. Changes included a new body with new paint and graphics, new dual waterproof digital high torque steering servos, Traxxas' new 2.4 gHz radio system, an improved "Optidrive" two speed reversing transmission, and new progressive 2 suspension rocker arms. Also, new deeper offset 3.8 inch "Geode" wheels increase overall width by 1 inch and new 6.3 inch "Monster Maxx" tires (lifted from the current T-Maxx) increase ground clearance by .25 inches to 4.25 inches and overall height by .9 inches to 11.02 inches.[11] #5309
The 5309 originally came out in 2004-2005. It was about the same as the new one, but the servos are better now, and the new 2.4 ghz for 2009. I don't know if they're referring to the revo 2.5 or the 5308 for it being bigger. It is the same chassis as the original 5309 and the 5308. I think the new 5309 has bigger tires/wheels than the original 5309. Maybe thats where they got that from. But yes, there is a new 5309.
So currently the New 5309 is the newest revo you can purchase?
But yet everyone says its the old one? when it is the most current model you can buy...
Is there something on the revo 3.3 that says if its the 5309 or 5308 and if its the 5309 is it the new one or the older one?
Thanks
5308 is the old model. The new 5309 have 2.4 Ghz radio, more powerful 2075 digital servo and bigger wheels and tires. It should be written on the end of the box which model it is. :)
Well that is kinda what i thought--- I didnt think that Traxxas was wrong about there own products--
What if ya dont have the Box it came in? i my revos on a trade-- so the guy didnt specify if which model-- Neither of them came with 2.4ghz but was has Reverse and dual steering servos and the other is forward only with one servo but neither of them are stock RPM arms and other stuff...
I was looking to see if the serial on the tranny told you which one is which?
The one with the single servo and the FOC is likely the 5308.
For the 5309, what color are the steering servo's? If they are blue(2075), it is likely the newer 5309, if they are black(2055) it is likely the older 5309. You can also check for the geode wheels, and 17 mm hexes that come on the newer version, vs 14 mm hexes on the older.
I have a 5309 model. i have the non waterproof servos and no 2.4 ghz radio. I still has the crystals.. so it beats the hell outta me
