asimons07
i recently took apart my (2) 3.3's and my 2.5r engines and did a little maintenance on them. i didnt replace anything just made sure everything was in working order and clean. i did remove the piston, sleeve and crank from the block. when i reassembled them, all 3 motors have the same issue. the piston seems to get stuck at the top of the sleeve now. i just catches a little bit. still easily turns over but these have never done this before. I'm assuming this is my fault seeing how all of them do it. i was also thinking that since they came apart maybe they didnt go back together exactly the same, maybe the shifting of parts "thousands of an inch" has something to do with it? a motor is broke in and gets used to running with all the parts in the exact location. maybe just simple taking it apart allowed things to go back together off just a liitle bit and running a few tanks may make it go away? please any suggestions would be greatful... Adam
